[petsc-dev] Making FE fields in the beginning
Matthew Knepley
knepley at gmail.com
Wed Nov 27 13:38:41 CST 2013
On Wed, Nov 27, 2013 at 12:43 PM, Geoffrey Irving <irving at naml.us> wrote:
> Currently, FE fields on a DMPlex are created with the function
> DMPlexProjectFunction
> This function has three issues:
> 1. It doesn't take a void* argument, and therefore requires global
> variables if you need to pass in additional data.
I am not opposed to DMPlex functions taking contexts. However, my
question is: how is intended to receive this context? So far, I am
unconvinced that PetscFE needs an outside context. It just seems like
bad design to me.
The original intention is to pass evaluation data in as a mesh field. How
does this break down?
> 2. It operates one quadrature point and a time, so is inefficient in
> situations where evaluation overhead can be amortized across multiple
> points (especially from scripts). For the workhorse FE routines this
> is inconvenient but acceptable since the goal is probably OpenCL, but
> it'd would be nice to have access to python and numpy in the setup
> phase.
I think this is oversimplified. DMPlex does operate in batches of quadrature
points, in fact in batches of cells (although the batch size is 1 now). It
is
PetscDualSpace that calls things one quad point at a time. I would think
that
he Python interface would come in at the level of the PetscDualSpace
evaluator. How
does this differ from what you had planned?
> 3. It doesn't pass a cell argument, so data in an existing mesh fields
> requires a hierarchy traversal to access.
I think I do not understand something fundamental about how you are using
this
function. This is intended to be an orthogonal projection of the function f
onto the
finite element space V. Why would we need a cell index or additional
information?
Is it because the function f you have is not analytic, but another mesh
field? I will
think about optimizing this case.
Matt
> I'm going to make an alternate version of DMPlexProjectFunction that
> addresses these issues. If you think it's too early to know the best
> way to do this in core petsc, I can put the routine in my code for now
> and we can revisit migrating it into petsc later. I'm fine either
> way. Concretely, these issues are solved by
> 1. Adding a void* argument.
> 2. Batching quadrature point evaluation.
> 3. Passing the cell index.
> so there aren't a lot of choices to get wrong. Really the only choice
> is who chooses the batch size.
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131127/3b73f59f/attachment.html>
