[petsc-dev] viewing factored matrices
Fri Nov 22 12:01:47 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
> So I assume you would have PCFactor set the prefix of the matrix to
> prefix+"pc_factor_" and call MatViewFromOptions() inside the PCView()?
That's what I had in mind.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131122/56639a98/attachment.sig>
