[petsc-dev] reminder about initializing structs
Jed Brown
jedbrown at mcs.anl.gov
Thu Nov 21 20:57:22 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> You can’t do this in C89, so please don’t do this in PETSc code since someone (me, will have to fix it later)
> src/dm/impls/da/dalocal.c: In function ‘DMDASetVertexCoordinates’:
> src/dm/impls/da/dalocal.c:1192:5: warning: initializer element is not computable at load time [enabled by default]
> PetscInt ind[3] = {0, 0, k + da->zs}, d, off;
Do any compilers actually reject this, or only warn with -std=c89? The
struct syntax is more compact and easier to read. I assume that
Microsoft will eventually completely drop support for their C compiler,
and then there will be no reason not to use basic C99 features.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131121/557d7488/attachment.sig>
