[petsc-dev] nightly builds progress
Tue Nov 19 14:35:57 CST 2013
On Sun, 17 Nov 2013, Satish Balay wrote:
> On Sun, 17 Nov 2013, Barry Smith wrote:
> >   It is ok to have some run at night and the others during the day. But they cannot overwrite each others output.
> There is no overriting hapenning. Just a single index for both builds
> - rotated by date.
> > You need to set it up so that they go in different places (even same directory is ok with different names) but generate TWO dashboards.
> Currently both logs go into a single location and a single dashboard
> gets genrated for all current logs [based on current date]. Its just
> the master logs get added at a later time of the day - and the
> dashboard gets regenerated at that time.
> > One for next and one for master, and both always available. So if I go to the bottom of the petsc-developers page there should always be two links to nightly builds one to master and one to next.
> I'll check on this. [I sometimes switch master builds with maint - so
> on some days - that part will be missing].
Pushed the necessary changes so that we have dashboards for each branch.
The firt run with the updated scripts should be today arround 9:00pm
Satish
