[petsc-dev] configure bug
Barry Smith
bsmith at mcs.anl.gov
Mon Nov 18 20:46:44 CST 2013
Matt, Jed, and Satish
Nightly test,
ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/11/18/configure_next_arch-opensolaris-cmplx-pkgs-dbg_n-gage.log
configure test clearly produces a warning but somehow this gets filtered out? So the make all is spewed with complaints about deprecated. How can this possibly get filtered out?
Barry
TEST configureDeprecated from PETSc.Configure(/export/home/petsc/petsc.clone-3/config/PETSc/Configure.py:676)
TESTING: configureDeprecated from PETSc.Configure(/export/home/petsc/petsc.clone-3/config/PETSc/Configure.py:676)
Check if __attribute((deprecated)) is supported
Pushing language C
Executing: /export/home/petsc/soft/mpich2-1.2.1p1/bin/mpicc -c -o /tmp/petsc-01nSWx/PETSc.Configure/conftest.o -I/tmp/petsc-01nSWx/config.setCompilers -I/tmp/petsc-01nSWx/config.compilers -I/tmp/petsc-01nSWx/config.headers -I/tmp/petsc-01nSWx/PETSc.utilities.cacheDetails -I/tmp/petsc-01nSWx/PETSc.utilities.getResidentSetSize -I/tmp/petsc-01nSWx/config.functions -I/tmp/petsc-01nSWx/PETSc.utilities.missing -I/tmp/petsc-01nSWx/config.packages.MPI -I/tmp/petsc-01nSWx/config.types -I/tmp/petsc-01nSWx/PETSc.utilities.scalarTypes -I/tmp/petsc-01nSWx/PETSc.packages.pthread -I/tmp/petsc-01nSWx/config.libraries -I/tmp/petsc-01nSWx/config.atomics -I/tmp/petsc-01nSWx/PETSc.Configure -fPIC -g /tmp/petsc-01nSWx/PETSc.Configure/conftest.c
Possible ERROR while running compiler:
stderr:
"/tmp/petsc-01nSWx/PETSc.Configure/conftest.c", line 3: warning: attribute "deprecated" is unknown, ignored
Source:
#include "confdefs.h"
#include "conffix.h"
__attribute((deprecated)) static int myfunc(void) { return 1;}
int main() {
return 0;
Defined "DEPRECATED(why)" to "__attribute((deprecated))"
Popping language C
