[petsc-dev] attempt at understanding PetscFEM
Jed Brown
jedbrown at mcs.anl.gov
Mon Nov 18 18:08:50 CST 2013
Geoffrey Irving <irving at naml.us> writes:
> Here's an attempt at the tensor definitions of all the functions in
> PetscFEM. Could you check if it looks correct, especially the
> Jacobian section?
Yes, this looks right. I write it without the index notation in my
paper (section 3.2 and 3.3).
http://59A2.org/na/Brown-EfficientNonlinearSolversNodalHighOrder3D-2010.pdf
FWIW, I do not agree with Matt's factoring into arrays of function
pointers, especially since material models should be reused. I think
he's willing to add support for having one function pointer that fills
up some tensors.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131118/ded898d5/attachment.sig>
