[petsc-dev] Vertex assignment in DMPlexDistribute
Matthew Knepley
knepley at gmail.com
Sat Nov 16 07:54:28 CST 2013
On Sat, Nov 16, 2013 at 7:22 AM, Michael Lange <michael.lange at imperial.ac.uk
> wrote:
> Hi,
> I notice that, when creating the point SF for the parallel partition in
> DMPlexDistribute, cells are assigned to procs according to the original
> partition but vertices aren't. Was this done by design or is this a bug?
If this were true, there would be no communication for the P1 test of SNES
ex12. Here is running it with
-interpolate 1 and -dm_view ::ascii_info_detail
PetscSF Object: 2 MPI processes
type: basic
sort=rank-order
[0] Number of roots=19, leaves=5, remote ranks=1
[0] 4 <- (1,6)
[0] 5 <- (1,8)
[0] 7 <- (1,9)
[0] 10 <- (1,13)
[0] 11 <- (1,17)
[1] Number of roots=19, leaves=0, remote ranks=0
[0] Roots referenced by my leaves, by rank
[0] 1: 5 edges
[0] 4 <- 6
[0] 5 <- 8
[0] 7 <- 9
[0] 10 <- 13
[0] 11 <- 17
[1] Roots referenced by my leaves, by rank
So there are 3 vertices and 2 edges in the point SF.
Matt
> In case it is a bug, I have attached a patch that fixes this by using the
> closure of the original partition instead.
> Thanks and kind regards
> Michael
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131116/e054b506/attachment.html>
