[petsc-dev] [pflotran-dev: 976] Re: [pflotran-users: 998] Distorted structured grid
Fri Nov 15 15:07:08 CST 2013
Jed Brown <jedbrown at mcs.anl.gov> writes:
>> Thanks for the reminder, I forgot that we were missing a specialized
>> function.  What I recommended should work and be fast with 'next'.  Can
>> you try that?
> Hang on, I messed something up.  Will fix and reply here.
Okay, done.  Please check it out in 'next'.
https://bitbucket.org/petsc/petsc/wiki/Home#markdown-header-following-petsc-development
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131115/83f4e5f7/attachment.sig>
