[petsc-dev] not finding --downloaded Generator for snes ex31
    Geoffrey Irving
    irving at naml.us
    Fri Nov 15 14:14:11 CST 2013
I'm trying to run some of the other FE examples, and am hitting the
following error.  As configure.log shows, --download-generator
succeeded.  Should I need a pythonpath tweak to get this to work?
Geoffrey
(irving/snes-ex12-cleanup) cayley:petsc% ./config/builder2.py check
src/snes/examples/tutorials/ex31.c
Namespace(args=[], files=['src/snes/examples/tutorials/ex31.c'],
func=<function check at 0x104ce60>, replace=False, retain=False,
testnum=None)
Running 10 tests
Traceback (most recent call last):
  File "./bin/pythonscripts/PetscGenerateFEMQuadrature.py", line 20, in <module>
    generator.setup()
  File "/home/irving/petsc/config/PETSc/FEM.py", line 867, in setup
    raise RuntimeError('Unable to find Generator package!\nReconfigure
PETSc using --download-generator.')
RuntimeError: Unable to find Generator package!
Reconfigure PETSc using --download-generator.
./bin/pythonscripts/PetscGenerateFEMQuadrature.py 2 2 2 1 laplacian 2
1 1 1 gradient 2 1 1 1 identity src/snes/examples/tutorials/ex31.h
Building ['/home/irving/petsc/src/snes/examples/tutorials/ex31.c']
ERROR IN C COMPILE ******************************
src/snes/examples/tutorials/ex31.c:62:18: fatal error: ex31.h: No such
file or directory                               compilation
terminated.
             ('ERROR: Missing object file', 'ex31.o')
TEST BUILD FAILED (check example.log for details)
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131115/d6456837/attachment.bin>
