[petsc-dev] best fix for -hosts localhost issue
Fri Nov 15 13:25:12 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
> No, it is any mpiexec from my laptop when it is not connected to Wifi. It
> hangs for the timeout
> when mpiexec does gethostbyname(), and then runs. Its horrible.
Could this be the problem?
http://stackoverflow.com/questions/4317432/gethostbyname-freezes-and-uses-100-cpu-on-mac-os-x
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131115/7fab5659/attachment.sig>
