[petsc-dev] PetscFEM routines missing user data arguments
    Geoffrey Irving
    irving at naml.us
    Fri Nov 15 12:14:18 CST 2013
On Fri, Nov 15, 2013 at 9:59 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Nov 15, 2013 at 11:42 AM, Geoffrey Irving <irving at naml.us> wrote:
>> On Thu, Nov 14, 2013 at 6:21 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Thu, Nov 14, 2013 at 8:14 PM, Geoffrey Irving <irving at naml.us> wrote:
>> >> On Thu, Nov 14, 2013 at 6:03 PM, Matthew Knepley <knepley at gmail.com>
>> >> wrote:
>> >> > On Thu, Nov 14, 2013 at 7:43 PM, Geoffrey Irving <irving at naml.us>
>> >> > wrote:
>> >> >> It doesn't look like there's currently a way to pass user data down
>> >> >> to
>> >> >> the various fields in PetscFEM.  Can I add an extra argument to each
>> >> >> function, or is that part of the API going to change in a way that
>> >> >> would obviate the extra argument?
>> >> > That is by design. Here is the rationale. I want to be able to use
>> >> > CUDA
>> >> > or OpenCL
>> >> > to evaluate these low-level FEM integration routines, so you can't
>> >> > pass
>> >> > in arbitrary context.
>> >> > I really don't think we should need arbitrary information at the
>> >> > lowest level integration.
>> >> > Right now you can pass in information using auxiliary fields. How
>> >> > would you use
>> >> > other stuff?
>> >> Well, you're probably not going to like application 1, which is
>> >> passing around PyObject*'s so I can write little FEM explorations in
>> >> numpy.  Is the field support the right thing to do for constant
>> >> fields, or integer valued constant fields?
>> > I should explain further. Here is the hierarchy:
>> >   SNESComputeFunction (global)
>> >   --> SNESComputeFunction_DMLocal (l2g)
>> >     --> DMPlexComputeResidualFEM (local)
>> >       --> PetscFEIntegrateResidual (chunk of cells)
>> >         --> kernel (batch of cells)
>> > I can be talked into a context all the way down to the kernel, which
>> > only integrates a few cells
>> > (like 32), but I would think that what you would do is write another
>> > PetscFE that calls Python
>> > (I have one for the CPU and one for OpenCL), and it has a context.
>> Thanks for the explanation, that helps.  And apologies for my
>> denseness, somehow I read the functions I was imagining adding a void*
>> to as having another layer of loop, when actually they are called per
>> quadrature point.  Obviously I need a slower more vectorized version
> Don't understand the vector comment.
Replace
    void f0_u(const PetscScalar u[], ...)
      f0[0] = 4.0;
with
    void f0_u(const PetscInt n, PetscScalar u[], ...)
      PetscInt i;
      for (i=0; i<n; i++)
        f0[i] = 4.0;
and then call it either once with data for all quadrature points for a
few times for batches.  I don't really think it's worth doing this,
when I could instead spend time setting up OpenCL kernels.  Again, I
somehow hallucinated that it was already like this, which is why I
thought of writing a Python testbed.
>> to send to Python as numpy arrays.  Since another version is required,
>> I will probably abandon my plan to write Python unit tests (I only
>> considered it because I hallucinated that it would be trivial), so I'm
>> good to go.
>> Getting back to actual physics examples, what would be the right way
>> to implement a uniform shell pressure term in this context?  In other
>> words, the force density at a point is pN, where p is a variable but
>> globally constant pressure and N is the shell surface normal.  Should
>> I just use a global variable?
> I would probably use a field since then I can make it non-constant if I want, and
> memory is not usually an issue.
Will do.
>> It seems like a slight design blemish that the OpenCL version owns the
>> OpenCL versions of its compute routines but accepts the CPU versions
>> as arguments, but feel free to ignore that as nitpickiness.
> That is absolute crap I agree. This is a stopgap until we learn how to have a
> unified representation.
Sounds good.  The most incremental solution would just be to move
control over those functions down to PetscFE.  Indeed, they pretty
much have to go at whichever level is supposed to know about OpenCL
kernels and the like.
Geoffrey
