[petsc-dev] COPTFLAGS
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Nov 13 11:37:30 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> I don't understand why this would be needed. Thid code sets the
> defaults for bopt='g' or 'O'. But if COPTFLAGS flags is set by user -
> it routine should not be called. [so the above 2 lines appear to be
> redundant]
How do you figure that the routine is not called when COPTFLAGS is set
by the user?
(And note that the function is called twice, once with bopt='' to get
warning flags and again with bopt in ['g', 'O'] to get
optimization/debug flags.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131113/41baab87/attachment.sig>
