[petsc-dev] DMPlex with vertical numbering?
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Nov 13 11:35:06 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
> If you need the local and global orders to match, I think the best
> thing to do is create the global section yourself, which should be as
> easy as creating the section.
As an aside, I think we need to make one nice annotated picture showing
what the various sections do.  The clarity that it would bring, and
ability to use common terminology, would be worth several hours of
effort to make a really good figure.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131113/356c0172/attachment.sig>
