[petsc-dev] PetscHashIJ scaling problem?
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Nov 11 16:02:32 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
> I rewrote insertion for DMLabel to use the hash table, and convert to flat
> arrays after insertion. Now its all linear:
Nice.  Did you check how many hash operations per second this works out
to?  Is this still the leading setup cost?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131111/2c2e067e/attachment.sig>
