[petsc-dev] de-global variablelizing PETSc
Barry Smith
bsmith at mcs.anl.gov
Sun Nov 10 19:07:29 CST 2013
On Nov 10, 2013, at 6:57 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>> What do tiny or fat Vecs have to do with wether
>> ISInitializePackage() and friends are called during some
>> initialization or “when needed” (and thus requiring some sort of
>> lock).
> That was a question of whether threads should have their own private
> library contexts. (That is the strongest separation you could have
> between threads, and would make some sense when multiple components of a
> large application use PETSc, but do not interact via PETSc.)
>> BTW: I am not opposed to ISInitializePackage() using a lock to
>> insure it is done only once per process, but I ain’t writing that
>> code.
> Okay, that's easy code, it just depends on what sort of portability we
> want for threaded code. (Non-threaded code will always just work.) For
> threaded, should we assume that (a) inline assembly is supported, (b)
> C11 stdatomic.h is available, or (c) OpenMP is available?
I assume this depends on what configure finds?
