[petsc-dev] de-global variablelizing PETSc
Jed Brown
jedbrown at mcs.anl.gov
Sun Nov 10 11:43:39 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> Why not go all the way and remove PetscInitialize()? The various
> initializations in there could also be done “on the fly, as needed”
> also with locks to make them safe. Why are some initializations done
> at startup and some done “as needed”?
Where do you going to get command line arguments (and otherwise
initialize an options database)?
I agree that most setup can be done lazily. I don't really care whether
each thread creates their own MPI types or PetscInitialize does it. If
we removed PetscInitialize, users would still have to call MPI_Init
themselves, and things like debugging/profiling still need to have
broader scope than an individual object, so I think we'd end up going
down tho road mentioned in the footnote of my other message.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131110/4231beac/attachment.sig>
