[petsc-dev] PetscHashIJ scaling problem?
    Matthew Knepley
    knepley at gmail.com
    Sun Nov 10 08:59:33 CST 2013
On Fri, Nov 8, 2013 at 11:56 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Jed Brown <jedbrown at mcs.anl.gov> writes:
> > $ time mpich-clang-optg/lib/ex26-obj/ex26 -N 1000
> > 0.870 real   0.857 user   0.010 sys   99.67 cpu
> > $ time mpich-clang-optg/lib/ex26-obj/ex26 -N 2000
> > 2.762 real   2.690 user   0.073 sys   100.03 cpu
> > 0.870 * 2^2 = 3.48
> > $ time mpich-clang-optg/lib/ex26-obj/ex26 -N 3000
> > 5.176 real   4.963 user   0.213 sys   100.01 cpu
> > 0.870 * 3^2 = 7.83
> > 2.762 * (3/2)^2 = 4.59
> > $ time mpich-clang-optg/lib/ex26-obj/ex26 -N 4000
> > 8.183 real   7.893 user   0.280 sys   99.88 cpu
> > 0.870 * 4^2 = 13.92
> > 2.762 * (4/2)^2 = 7.63
> > 5.176 * (4/3)^2 = 8.95
> > This looks stable at about 2 million lookups and insertions per second
> > (or 4M hash operations).
> If we use the khash API the way it was intended (via kh_put and kh_val;
> ignore the ugly API inconsistency)
>   PetscHashICreate(table);
>   for (i = 0; i < N; ++i) {
>     for (j = 0; j < N; ++j) {
>       PetscInt key = (PetscMin(i,j) << 16) + PetscMax(i,j);
>       khint_t ret,idx = kh_put(HASHI,table,key,&ret);
>       if (ret == 1) kh_val(table,idx) = newp++;
>   PetscHashIDestroy(table);
> we get numbers that are about twice as good (no weird chaining and only
> one lookup):
> $ for n in 1000 2000 3000 4000; do time mpich-clang-optg/lib/ex26-obj/ex26
> -N $n; done
> 0.462 real   0.453 user   0.007 sys   99.59 cpu
> 1.476 real   1.457 user   0.020 sys   100.01 cpu
> 2.791 real   2.767 user   0.023 sys   99.96 cpu
> 3.927 real   3.893 user   0.037 sys   100.06 cpu
> The debug-mode performance is also tons better.
> I see another hash table shootout by a good developer:
> http://preshing.com/20110603/hash-table-performance-tests/
> The fastest in his comparison uses simple chaining instead of double
> hashing (which khash uses).  I don't have a direct comparison of the
> two, and Jeff's version is hashing strings, so it would have to be
> modified/simplified to compare directly.
> Does your algorithm need lots better than 4M hash lookups per second, or
> do we just need to optimize the current implementation?
Okay, here is the clearly quadratic performance, and its in next. Build
SNES ex12 and run using
/PETSc3/petsc/petsc-dev/arch-c-opencl-opt-next/lib/ex12-obj/ex12 -run_type
perf -refinement_limit 0.00000625 -variable_coefficient field
-petscspace_order 1 -mat_petscspace_order 0 -show_initial 0 -show_solution
0 -petscfe_type basic -log_summary -interpolate
-refinement_limit 0.000625     DMPlexInterpolate       4 1.0 1.7443e-02 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 12  0  0  0 24  12  0  0  0 24     0
-refinement_limit 0.0003125    DMPlexInterpolate       4 1.0 3.3111e-02 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 13  0  0  0 24  13  0  0  0 24     0
-refinement_limit 0.0000625    DMPlexInterpolate       4 1.0 2.3465e-01 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 21  0  0  0 24  21  0  0  0 24     0
-refinement_limit 0.00003125   DMPlexInterpolate       4 1.0 7.7508e-01 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 30  0  0  0 24  30  0  0  0 24     0
-refinement_limit 0.000015625  DMPlexInterpolate       4 1.0 2.7267e+00 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 42  0  0  0 24  42  0  0  0 24     0
-refinement_limit 0.0000078125 DMPlexInterpolate       4 1.0 1.0175e+01 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 58  0  0  0 24  58  0  0  0 24     0
-refinement_limit 0.00000625   DMPlexInterpolate       4 1.0 3.8912e+01 1.0
0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01 72  0  0  0 24  72  0  0  0 24     0
You can see the quadratic complexity kick in, and this is what people are
complaining about. Does this mean
we have to ditch kh_hash, or have I done something wrong.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131110/d96b0d7f/attachment.html>
