[petsc-dev] PetscHashIJ scaling problem?
Fri Nov 8 10:58:43 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
> I think I have tracked down the DMPlex performance issue to a problem with
> PetscHashIJKL. I replaced it with PetscHashIJ in 2D, and I still have bad
> behavior. I made a simple test and the growth of runtime is definitely
> superlinear. The test is ex26 in knepley/fix-hash-scaling. I get
> next *$:/PETSc3/petsc/petsc-dev$
> /PETSc3/petsc/petsc-dev/arch-c-opencl-next/lib/ex26-obj/ex26 -N 100
> -log_summary | grep "(sec):" | cut -c 23-32
Your use of grep conceals the fact that you are not running in optimized mode.
> 6.067e-01
> /PETSc3/petsc/petsc-dev/arch-c-opencl-next/lib/ex26-obj/ex26 -N 110
> 1.491e+00
> /PETSc3/petsc/petsc-dev/arch-c-opencl-next/lib/ex26-obj/ex26 -N 120
> 2.913e+00
> /PETSc3/petsc/petsc-dev/arch-c-opencl-next/lib/ex26-obj/ex26 -N 130
> 4.892e+00
> /PETSc3/petsc/petsc-dev/arch-c-opencl-next/lib/ex26-obj/ex26 -N 140
> 6.812e+00
> /PETSc3/petsc/petsc-dev/arch-c-opencl-next/lib/ex26-obj/ex26 -N 150
> 9.777e+00
This test is a nested loop so it should scale quadratically.
$ time mpich-clang-optg/lib/ex26-obj/ex26 -N 1000
0.870 real   0.857 user   0.010 sys   99.67 cpu
$ time mpich-clang-optg/lib/ex26-obj/ex26 -N 2000
2.762 real   2.690 user   0.073 sys   100.03 cpu
0.870 * 2^2 = 3.48
$ time mpich-clang-optg/lib/ex26-obj/ex26 -N 3000
5.176 real   4.963 user   0.213 sys   100.01 cpu
0.870 * 3^2 = 7.83
2.762 * (3/2)^2 = 4.59
$ time mpich-clang-optg/lib/ex26-obj/ex26 -N 4000
8.183 real   7.893 user   0.280 sys   99.88 cpu
0.870 * 4^2 = 13.92
2.762 * (4/2)^2 = 7.63
5.176 * (4/3)^2 = 8.95
This looks stable at about 2 million lookups and insertions per second
(or 4M hash operations).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131108/13b1f5e9/attachment.sig>
