[petsc-dev] stencils, ex2f.F, openmp
Gryllida
gryllida at fastmail.fm
Thu Nov 7 22:01:58 CST 2013
On Fri, 8 Nov 2013, at 14:08, Gryllida wrote:
> On Fri, 8 Nov 2013, at 10:09, Svetlana Tkachenko wrote:
> > ex2f.F involves a band matrix with 4 on main diagonal and -1s on the sub-diagonals. I have A_central matrix which stores the -4s, and A_left, A_right, Atop, A_bottom matrices which store the -1s (they actually are more complicated numbers than that). Would it be recommended to simply wrap the "do 10, II=..." block like the one in ex2f.F into $OMP DO to speed up filling of the matrix as each of the values set can be set independently of others? (I tried doing so but got a segmentation fault and I'm working on a small example to reproduce the problem.)
> > Svetlana
> I figured out this is called 'stencils' correctly and corrected the subject.
> Trying to use example ex22f.F but it's quite involved.
> Svetlana
Found http://scicomp.stackexchange.com/questions/2224/how-should-i-build-a-2d-5-point-stencil-laplacian-matrix-in-parallel/2228 and will try to follow Jed Brown's advice.
