[petsc-dev] make all PETSc Fortran examples modern freeform?
Thu Nov 7 12:51:04 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
>> Surely we don't need to make *.F90 examples work with -ffixed-form.
> yes thats what I meant. [.F90 examples should not run when configured with fixed-form]
> Also - I don't see a big need for users to install PETSc with
> FFLAGS=-fixed-form or FFLAGS=-free-form.
I agree that there is no point to FFLAGS=-fixed-form, but
FFLAGS=-free-form might be needed to confirm that all our *.F files
compile correctly as free form.
> The current default build is more univeral - and the users can either
> name their sourcefiles .F or .F90 based on fixed/free form.
Yes, I assume Barry started the thread because it's ugly and error-prone
to write polyglots.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131107/784a2af9/attachment.sig>
