[petsc-dev] openmp
Wed Nov 6 21:45:58 CST 2013
Svetlana Tkachenko <svetlana.tkachenko at fastmail.fm> writes:
>> > What do you mean? (I don't think the program name has to be 'main'.).
>> No, it doesn't.  The name is meaningless in Fortran, but you need to use
>> the keyword "program".
>> > ~/dev/test/petsc $ cat myexample.F90
>> >        program myexample
>> >            call solver
>> >        end
>> > ~/dev/test/petsc $
>> Add myexample.o to the makefile so it gets compiled.
> Already did, please, see:
> ~/dev/test/petsc $ cat makefile
> myexample: myexample.o solver.o
>                 ${CLINKER} -o $@ $^ ${PETSC_LIB}
> include ${PETSC_DIR}/conf/variables
> include ${PETSC_DIR}/conf/rules
> ~/dev/test/petsc $
Run make clean; make.  If you get the same error, check
$ nm myexample.o
                 U _gfortran_set_args
                 U _gfortran_set_options
                 U _GLOBAL_OFFSET_TABLE_
0000000000000000 T main
0000000000000000 r options.0.1881
                 U solver_
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131106/8e6a3aad/attachment.sig>
