[petsc-dev] openmp
Svetlana Tkachenko svetlana.tkachenko at fastmail.fm
Wed Nov 6 19:53:05 CST 2013
On Thu, 7 Nov 2013, at 10:22, Jed Brown wrote:
> Svetlana Tkachenko <svetlana.tkachenko at fastmail.fm> writes:
> > Right. I have spent half of an hour now trying to imagine what to do
> > to link trying everything like a headless chicken and it did not
> > work.
> You always have to send the error message.
> > I would appreciate if you could come up with something that links, not
> > just runs a single program.
> The makefiles we suggested link a program of the same name as the source
> file.  Do you have multiple source files?  You only have to edit the one
> line and run "make".
> program: several.o object.o files.o
> 	${CLINKER} -o $@ $^ ${PETSC_LIB}
> include ${PETSC_DIR}/conf/variables
> include ${PETSC_DIR}/conf/rules
> Email had 1 attachment:
> + Attachment2
>   1k (application/pgp-signature)
~/dev/test/petsc $ cat makefile
myexample: myexample.o solver.o
~/dev/test/petsc $ cat solver.f
          subroutine solver()
#include <finclude/petscsys.h>
            PetscErrorCode ierr
            print *, "Entered petsc."
              ! Init PETSc
              call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
              CHKERRQ(ierr)
              print *, "Init done."
              ! Finalise PETSc
              call PetscFinalize(ierr)
              CHKERRQ(ierr)
              print *, "Finalized."
          end
~/dev/test/petsc $ make
gfortran -c  -fPIC -Wall -Wno-unused-variable -g  -fopenmp  -o solver.o solver.f
Warning: solver.f:2: Illegal preprocessor directive
solver.f:3.12:
            PetscErrorCode ierr
            1
Error: Unclassifiable statement at (1)
solver.f:8.14:
              CHKERRQ(ierr)
              1
solver.f:13.14:
              CHKERRQ(ierr)
              1
make: [solver.o] Error 1 (ignored)
gcc -fopenmp -fopenmp   -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 -fopenmp  -o myexample myexample.o solver.o -Wl,-rpath,/home/<username>/petsc/linux-amd64/lib -L/home/<username>/petsc/linux-amd64/lib  -lpetsc -Wl,-rpath,/home/<username>/petsc/linux-amd64/lib -lflapack -lfblas -lX11 -lpthread -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -lgfortran -lm -lm -lstdc++ -lstdc++ -ldl -lgcc_s -ldl
gcc: solver.o: No such file or directory
make: *** [myexample] Error 1
~/dev/test/petsc $
