[petsc-dev] General Advice for Solving SVD and Eigenvalue problems using SLEPc
Jed Brown
jedbrown at mcs.anl.gov
Wed Nov 6 19:08:07 CST 2013
Chris Eldred <chris.eldred at gmail.com> writes:
> 3) Is it worthwhile to use a non-sparse (dense) solver library
> (something like Elemental?) since I need to construct the entire
> eigenspace anyways?
The matrix of eigenvectors is dense so you'll end up doing this much
work anyway. Your problems are not so terribly large, so I would use
Elemental's eigensolvers.
If you need to solve problems that are a great deal larger, I would
seriously reconsider the "need" for a complete eigenspace.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131106/b9964947/attachment.sig>
