[petsc-dev] problems with cmake
Sun Nov 3 00:53:11 CDT 2013
Jose David Bermeol <jbermeol at purdue.edu> writes:
> Hi, I've working with the new pardiso solver, I've testing in different platforms and I found a problem. When I configure petsc I get the following output:
> hypre:
>   Includes: -I/home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/linux/include
>   Library:  -Wl,-rpath,/home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/linux/lib -L/home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/linux/lib -lHYPRE
>   Arch:
> mkl-pardiso:
>   Includes: -I/apps/rhel6/intel/composer_xe_2013.3.163/mkl/include
>   Library:  -Wl,--start-group -L/apps/rhel6/intel/composer_xe_2013.3.163/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -Wl,--end-group -lpthread -lm -liomp5
> MUMPS:
>   Library:  -Wl,-rpath,/home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/linux/lib -L/home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/linux/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord
> Everything look right to me. But when I'm compiling Petscwith cmake I get that the includes are wrong
> [  0%] Building Fortran object CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o
> /apps/rhel6/intel/impi/4.1.0.030/bin64/mpiifort  -D__INSDIR__="" -fPIC -O3    -module include -I/home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/include -I/home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/linux/include -I/home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/-I/apps/rhel6/intel/composer_xe_2013.3.163/mkl/include -I/apps/rhel6/valgrind/3.8.1/include -I/apps/rhel6/intel/impi/4.1.0.030/intel64/include    -c /home/jbermeol/Nemo5_Intel_E/libs/petsc/build-real/src/sys/f90-mod/petscsysmod.F -o CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o
> As you see there is a missing space, so I don't know to much about cmake or how to fix this, so any help would be great.
Does your configure concatenate the strings without an intervening
space?  I don't think we've seen this before, but if you send a
reproducible test case, I'll look at it.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131102/08d37835/attachment.sig>
