[petsc-dev] PETSc developers who use weird MPI
Sat Nov 2 14:47:13 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Should 'prbrune/sf-sfbasicops' and 'prbrune/mat-matcolor' be cleaned
> up to remove the merge between the 'rebased' and 'non-rebased'
> variants of the branches - before the changes got into master?
This looks possible.
*   5c44807 (prbrune/mat-matcolor) Merge branch 'prbrune/sf-sfbasicops' into prbrune/mat-matcolor
| *   8e99f7e (prbrune/sf-sfbasicops) Merge branch 'prbrune/sf-sfbasicops' of bitbucket.org:petsc/petsc into prbrune/sf-sfbasicops
| | * f3fe83a mpiuni: change types to use unique IDs [for sf]
| | * 13d1d6f mpiuni: add MPI_OP definitions required for sfbasic
| * | a49f225 Added several additional MPI_Ops to PetscSFBasic.
* | 3142415 Fix for multiple definitions in mat/color/interface/ custom fortran bindings
$ diff -u  <(git show --format=fuller 53deab3) <(git show --format=fuller a49f225)
--- /dev/fd/63  2013-11-02 13:40:30.964494674 -0600
+++ /dev/fd/62  2013-11-02 13:40:30.964494674 -0600
@@ -1,8 +1,8 @@
-commit 53deab39b05c95f82ded0f9b5ed98e1eca77ec57
+commit a49f225f21e5e022456a96fbd0a3a873045b2c5d
 Author:     Peter Brune <brune at mcs.anl.gov>
 AuthorDate: Wed Oct 9 14:54:51 2013 -0500
 Commit:     Peter Brune <brune at mcs.anl.gov>
-CommitDate: Wed Oct 9 14:54:51 2013 -0500
+CommitDate: Thu Oct 17 13:38:04 2013 -0500
$ git branch -r --contains a49f225
  origin/prbrune/mat-matcolor
  origin/prbrune/sf-sfbasicops
Peter's rebased commit is a49f225, but it does exactly the same thing as
the original (53deab3) and the only other branch it has been used by is
'prbrune/mat-matcolor', so it should be okay to:
$ git checkout prbrune/sf-sfbasicops
$ git reset --hard f3fe83a        # gets rid of rebased version and merge
$ git checkout prbrune/mat-matcolor
$ git reset --hard HEAD^          # moves back to 3142415
$ git merge prbrune/sf-sfbasicops
Test that the above works, then force-push those two branches.
$ git push origin +prbrune/sf-sfbasicops +prbrune/mat-matcolor
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131102/edf55cfa/attachment.sig>
