[petsc-dev] PETSc developers who use weird MPI
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Nov  2 12:07:46 CDT 2013
On Nov 1, 2013, at 9:59 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 1 Nov 2013, Barry Smith wrote:
>>> If there are dependencies like 'prbrune/sf-sfbasicops ->
>>> prbrune/mat-matcolor -> barry/saws ' we need extra effort to keep
>>> track of these paths - and make sure the fixes - if any - get
>>> propogated the same way.
>>   Like how are we going to do that? Every time someone merges to next I check it and decide if that branch also needs to be merged into all my long living branches. Yeah like that is going to happen.
> I don't think you are supporsed to do that unless you specifically need
> the features from this branch. And then you keep track of future
> fixes - and see if you need to remerge.
>>   The reason I had to merge all that stuff into saws was that saws could not merge into next because those branches so changed next. I had to merge them into saws before I could get saws into next. But I missed 1/2 a one (somehow) getting an outdated verson of the sf-sfbasics into saws.
> No the more appropriate thing here would be to merge/rebase to latest
> master.
   Doesn’t work because those things are not in master; in fact the first thing I did was to merge in master then I needed to merge in the other things in order to get into next
> And then attempt to merge saws to next.
> Satish
