[petsc-dev] PETSc developers who use weird MPI
Satish Balay
balay at mcs.anl.gov
Fri Nov 1 21:29:28 CDT 2013
On Fri, 1 Nov 2013, Satish Balay wrote:
> Somehow the snapshot of 'prbrune/sf-sfbasicops' [prior to my fix] got merged into 'barry/saws'
> [I'll have to check these branches to see the path.]
> The fix is to merge latest 'prbrune/sf-sfbasicops' in the same pathway it got into 'barry/saws'
Ok the branches that have the offending commit:
balay at mockingbird /home/balay/petsc (barry/saws)
$ git branch -r --contains 53deab3
origin/barry/saws
origin/madams/sr-driver
origin/next
origin/prbrune/fas-gscolorsecant
origin/prbrune/mat-matcolor
origin/prbrune/sf-sfbasicops
Now see which of of the above branches got merged to 'barry/saws'
$ git log --merges --oneline |head
d548240 Merge branch 'prbrune/mat-matcolor' into barry/saws
fcaff9f Merge branch 'jed/check-pointer-runtime' into barry/saws
7737a22 Merge branch 'master' into barry/saws
ad7c120 Merge branch 'knepley/feature-test-parser'
b4a5846 Merge branch 'prbrune/snes-qnscaling'
f5cedc2 Merge branch 'knepley/feature-plex-refine-3d'
1fa8f14 Merge branch 'knepley/feature-plex-reordering'
dc1b40d Merge branch 'maint'
7390fa2 Merge branch 'balay/configure-winpython-check' into maint
39481a4 Merge branch 'balay/add-newline-between-stdout-stderr' into maint
Looks like Barry merged 'prbrune/mat-matcolor' into 'barry/saw'
balay at mockingbird /home/balay/petsc (prbrune/mat-matcolor)
70ec7f0 Merge branch 'prbrune/sf-sfbasicops' into prbrune/mat-matcolor
16407d4 Merge branch 'master' into prbrune/mat-matcolor
76ef003 Merge branch 'jed/datafiles-inherit'
35132eb Merge branch 'jed/dmvecmattypes-stdcoords'
7f96713 Merge branch 'jed/options-insert-bcast-bgq'
13cbb55 Merge branch 'jed/avoid-getpwuid'
b15a537 Merge branch 'knepley/fix-windows-download'
2c3e1d3 Merge branch 'balay/__float128-fix-download-f2cblas-mesg'
7a7ac0e Merge branch 'maint'
a04acb8 Merge branch 'jed/fix-fieldsplit-mg-example'
Ok peter merged the 'prbrune/sf-sfbasicops' snapshot prior to my fix
into 'prbrune/mat-matcolor'
ok prbrune/sf-sfbasicops -> prbrune/mat-matcolor -> barry/saws
So the fix is to do the same merges with the latest prbrune/sf-sfbasicops
Peter?
Satish
