[petsc-dev] PETSc developers who use weird MPI
    Satish Balay
    balay at mcs.anl.gov
    Fri Nov  1 20:33:39 CDT 2013
I thought I already fixed this. Which branch are these errors in?
http://lists.mcs.anl.gov/pipermail/petsc-dev/2013-October/013510.html
$ git branch -r --contains 13d1d6fd6eea58bc05ab56819e591ed4a281466f
  origin/next
  origin/prbrune/sf-sfbasicops
Satish
On Fri, 1 Nov 2013, Barry Smith wrote:
>    please always test with mpiuni before pushing when you use weird MPI
> src/vec/is/sf/impls/basic/sfbasic.c: In function ‘PetscSFBasicPackGetUnpackOp’:
> src/vec/is/sf/impls/basic/sfbasic.c:594:18: error: ‘MPI_PROD’ undeclared (first use in this function)
> src/vec/is/sf/impls/basic/sfbasic.c:594:18: note: each undeclared identifier is reported only once for each function it appears in
> src/vec/is/sf/impls/basic/sfbasic.c:597:18: error: ‘MPI_LAND’ undeclared (first use in this function)
> src/vec/is/sf/impls/basic/sfbasic.c:598:18: error: ‘MPI_BAND’ undeclared (first use in this function)
> src/vec/is/sf/impls/basic/sfbasic.c:599:18: error: ‘MPI_LOR’ undeclared (first use in this function)
> src/vec/is/sf/impls/basic/sfbasic.c:600:18: error: ‘MPI_BOR’ undeclared (first use in this function)
> src/vec/is/sf/impls/basic/sfbasic.c:601:18: error: ‘MPI_LXOR’ undeclared (first use in this function)
> src/vec/is/sf/impls/basic/sfbasic.c:602:18: error: ‘MPI_BXOR’ undeclared (first use in this function)
> src/vec/is/sf/impls/basic/sfbasic.c: In function ‘PetscSFBasicPackGetFetchAndOp’:
>    It is frustrating to get this kind of crap all the time after pulling.
>    Thanks
>     Barry
