[petsc-dev] headsup: default externalpackages dir is now	PETSC_DIR/PETSC_ARCH/externalpackages
    Peter Lichtner
    peter.lichtner at gmail.com
    Fri Nov  1 11:50:57 CDT 2013
Excellent change!
...Peter
On Nov 1, 2013, at 10:16 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Just a headsup.
> With the latest 'master' branch - the location of externalpackages is
> changed from PETSC_DIR/externalpackages to
> PETSC_DIR/PETSC_ARCH/externalpackages.
> So if you rerun configure on master branch - this new location will be used.
> Satish
________________
Peter Lichtner
Santa Fe, NM 87507
(505) 692-4029 (c)
OFM Research
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131101/76e977ba/attachment.html>
