[petsc-dev] ViennaCL-bindings in next
Karl Rupp
rupp at mcs.anl.gov
Sun Mar 24 20:30:16 CDT 2013
Hi Dave,
> I'm very interested in trying out your new ViennaCL interface in the near
> future. Looking at the documentation of ViennaCL online, it looks like there
> are preconditioners available within ViennaCL. Are there plans to provide
> petsc interfaces to the ViennaCL preconditioners in the near future?
Yes, there are a few preconditioners in ViennaCL already, most of them
using the CPU for the setup phase. I'm planning to make them available
in PETSc as well, plus adding more GPU-based preconditioners. Stay tuned :-)
Best regards,
Karli
> Karl Rupp writes:
> > Hi,
> > the interface to ViennaCL [1] has just been merged to 'next', enabling
> > PETSc to use OpenCL-enabled devices (most notably Intel's Xeon Phi and
> > GPUs from AMD in addition to the existing NVIDIA bindings). I tested it
> > with Vector-, Matrix-, and KSP- examples.
> > The new bindings are enabled by the configure flags
> > --download-viennacl
> > --with-opencl-include=/path/to/OpenCL-Headers
> > --with-opencl-lib=/path/to/libOpenCL.so
> > The OpenCL headers can be obtained on the Khronos webpage [2] and are
> > often available via package managers, e.g.
> > $> sudo apt-get install opencl-headers
> > or
> > $> sudo yam install opencl-headers
> > In such case, the OpenCL include directory is typically /usr/include
> > (BuildSystem may not detect these headers correctly on Mac OS, I'm
> > working on this). The OpenCL library comes with your graphics driver and
> > is usually located at /usr/lib/. There is no separate compiler as for
> > CUDA needed!
> > FAQ:
> > - What is the performance difference between OpenCL and CUDA for GPUs?
> > My experience is that for large problem sizes they are equivalent for
> > almost all linear algebra kernels. For small problem sizes (kernel
> > execution less than 1ms), CUDA is currently superior because of lower
> > latency.
> > - Which solvers can I use with the ViennaCL-bindings?
> > The same as with CUSP. Most notably the usual CG, BiCGS, GMRES.
> > - Which preconditioners are provided in the ViennaCL-bindings?
> > Currently none. You can, however, use all the standard CPU-based
> > preconditioners in PETSc together with ViennaCL matrices and vectors.
> > - Which command line options do I need to use?
> > Use -vec_type viennacl -mat_type aijviennacl
> > On Intel's Xeon Phi you also need to pass -viennacl_device_accelerator.
> > (If you read this email in an archive: Check the manual for current flags).
> > Best regards,
> > Karli
> > [1] http://viennacl.sourceforge.net/
> > [2] http://www.khronos.org/registry/cl/
