[petsc-dev] moab nightlybuild failure
    Satish Balay
    balay at mcs.anl.gov
    Wed Jun 26 22:48:24 CDT 2013
Moab builds are failing perhaps after switching to using git repo [if
git exists] from tarball. This is due to the missing 'configure'
script in the repo [which presumably needs to be generated.
https://bitbucket.org/petsc/petsc/commits/850bbba3e5b7b9c06b5231d4621b4fd248124420
How do we fix this?
[well if using git repo - we might have to check for additional
dependency 'autoreconf' and run 'autoreconf -fi'. But if it doesn't
exist - do we fall back to tarball or just error out? And I have no
idea where such code would go in the 'GNUPackage' notation]
Satish
                          Running configure on MOAB; this may take several minutes
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Error running configure on MOAB: Could not execute "cd /sandbox/petsc/petsc.clone-3/externalpackages/moab && ./configure --prefix=/sandbox/petsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib CC="/sandbox/petsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib/bin/mpicc" CFLAGS=" -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 " CXX="/sandbox/petsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib/bin/mpicxx" CXXFLAGS="  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g  -fPIC  " F90="/sandbox/petsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib/bin/mpif90" F90FLAGS=" -fPIC  -Wall -Wno-unused-variable -Wno-unused-dummy-argument -g " F77="/sandbox/petsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib/bin/mpif90" FFLAGS=" -fPIC  -Wall -Wno-unused-variable -Wno-unused-dummy-argument -g " FC="/sandbox/petsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib/bin/mpif90" FCLAGS=" -fPIC  -Wall -Wno-unused-variable -Wno-unused-dummy-argument -g " --enable-shared --with-mpi=/sandbox/p
 etsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib --with-hdf5=/sandbox/petsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib --with-netcdf=/sandbox/petsc/petsc.clone-3/arch-linux-pkgs-cxx-mlib":
/bin/sh: ./configure: No such file or directory
