[petsc-dev] Uncrustify has fucked up my file
Karl Rupp rupp at mcs.anl.gov
Thu Jan 31 19:58:41 CST 2013
> I am abiding by all the screwed up stuff that is written down. Not what
> isn't.
Well...
> The blank lines were in the middle of code, not between variables and code.
You can revert that if you feel the need to. They were introduced
occasionally in order to allow for a better dispatch about when to align
at '=' and when not. Example:
ierr = some_operation();
super_long_variable_name_that_screws_everything_up = x;
Clearly you don't want to align at '=' in this case. I wasn't aware
about your reluctance with respect to blank lines (yes, they occur in
other parts of PETSc regularly), so feel free to revert this if you
think that you are making our lives less harder than you make yours easier.
Best regards,
Karli
