[petsc-dev] Uncrustify has fucked up my file
    Jed Brown
    jedbrown at mcs.anl.gov
    Thu Jan 31 19:38:07 CST 2013
On Thu, Jan 31, 2013 at 7:26 PM, Matthew Knepley <knepley at gmail.com> wrote:
> You think the moustache looks nice.
Sounds like envy to me. ;-)
> When did we start prescribing blank lines in the middle of source?
Between variable declarations and usage? It has been there since 2004.
> And lining
> up the variables with the pointer mark is crazy. If this is in the manual,
> I want
> a revote on that.
This has been Barry's coding style for all the code I've seen. In lieu of
an explicit statement about coding style, the style used by existing code
_is_ the proper style unless a change is agreed upon. So I would argue this
has always been the established standard.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130131/f5d43d8f/attachment.html>
