[petsc-dev] make error
    Karl Rupp
    rupp at mcs.anl.gov
    Mon Jan 28 15:04:59 CST 2013
Hi Mark,
sorry, my bad. I'm fixing this.
Best regards,
Karli
On 01/28/2013 03:02 PM, Mark F. Adams wrote:
> I pulled today and did a deep clean but get this error:
> [ 37%] Building C object CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/pmap.c.o
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c: In function 'VecView_MPI_ASCII':
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:144: error: expected expression before 'else'
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:145: error: expected expression before 'else'
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:149: error: expected expression before 'else'
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:340: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:436: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:511: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:623: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:795: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:853: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:862: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:884: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:937: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:990: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:1024: error: nested functions are disabled, use -fnested-functions to re-enable
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:1067: error: expected declaration or statement at end of input
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pdvec.c:1067: warning: control reaches end of non-void function
> make[5]: *** [CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/pdvec.c.o] Error 1
