[petsc-dev] Making a PetSc Roll and Rocks Module
Thu Jan 24 19:06:36 CST 2013
On Thu, 24 Jan 2013, Matthew Knepley wrote:
> On Thu, Jan 24, 2013 at 6:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Fri, 25 Jan 2013, Blaise A Bourdin wrote:
> > > the usual naming scheme is just the version number, but for petsc, most
> > supercomputing centers use %version-%arch
> > > the installer will copy the file into $MODULEPATH/petsc/%version-%arch,
> > or the user to $HOME/.modulefiles
> > > Of course,  %version-%arch is a really silly name out of context. How
> > about petsc-%version-%arch, somewhere within $PETSC_DIR/$PETSC_ARCH, or
> > $PETSC_DIR/$PETSC_ARCH/modulefiles/%version-%arch ?
> > And PETSC_ARCH has no singificance with prefix install [the
> > significant text is in the prefix-path - and one doesn't have to match
> > PETSC_ARCH to this significant text]
> Are you pushing this or should i?
> > BTW: Is the following notation ok? [google didn't help]
> > prepend-path PATH /home/balay/spetsc/asterix64/bin:/home/balay/spetsc/bin
> > I have some fixes [except for the modfile name] which I can push.
> Cool, do it.
pushed my changes.
Satish
