[petsc-dev] Fwd: Nightly tests quick summary page
Thu Jan 24 12:56:21 CST 2013
On Thu, Jan 24, 2013 at 9:55 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Satish had gcov working before, but it just did not prove to be very
> useful. First, we generally write tests
> to look at the workflow for something rather than as a unit test. Second,
> coverage ignores the path you
> take to get to a certain line of code. My impression is that these things
> are only useful when they tell you
> lines which are never exercised.
The classical objective of coverage is to find which lines are never
executed, so that you can either (a) eliminate the dead code or (b) write
better tests. A less direct objective, which would use the information in a
different way, is to detect redundant or mergeable tests. I could be wrong,
but I have a feeling that PETSc has a lot of tests that are not really
distinct. (The same applies to tutorials. They get cleaned up occasionally,
but there have been a lot of copies with only a few lines changed.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130124/66e7ad42/attachment.html>
