[petsc-dev] Nightly tests quick summary page
Karl Rupp
rupp at mcs.anl.gov
Wed Jan 23 16:37:05 CST 2013
Dear PETScians,
I've adopted the HTML summary page script for the style checks a little
in order to have a quick overview of the results of our nightly tests:
http://krupp.iue.tuwien.ac.at/petsc-test/
It doesn't do anything fancy, particularly no automatic bisection or the
like, but it gives an overview of the Nightly results in seconds (which
are not overly good at the moment...).
Assuming that there is no question about the need for improving our
current automatic testing environment, it's merely a question of how far
we want to go. Regarding overall productivity, I made good experiences
with just using CTest and setting the summary page as the start page of
my browser. It's not overly complicated an can be integrated with
reasonable effort into our CMake build system.
We could also do all the fancy things provided by continuous integration
systems. Sadly, I don't have any experience on that front. Regardless, I
still prefer rather simple systems which are in daily use and fairly
robust rather than a complex,
it-can-do-anything-for-you-if-you-find-the-right-switch system that is
never set up...
Any thoughts/experiences? I know Jed has good plans on a testing
environment, so this is not meant to be an assault on him ;-)
Best regards,
Karli
