[petsc-dev] Style Guide: How to format single-line if/for/while-blocks?
Karl Rupp rupp at mcs.anl.gov
Mon Jan 21 22:45:41 CST 2013
Hi Jed,
> This has a nice picture of the way clean clean and smudge filters work.
> http://git-scm.com/book/ch7-2.html#Keyword-Expansion
> The idea is that you tell git to use your filter in a place that is not
> checked into the repository:
> echo '*.c filter=petscfmt' >> .git/info/attributes
> (If you wanted it to be checked in, you'd put it in .gitattributes, but
> we don't want that now.) Then set what the petscfmt filter does
> git config filter.petscfmt.clean 'uncrustify read from stdin and write
> clean version to stdout'
> git config filter.petscfmt.smudge 'uncrustify read from stdin and write
> smudged version to stdout'
> The smudged version is whatever the user wants to interact with, the
> cleaned version is whatever should go in the PETSc repository. (You can
> also just edit these filters in .git/config.)
Perfect, this will actually work with any source code transformation
tool. :-)
Best regards,
Karli
