[petsc-dev] Style Guide: How to format single-line if/for/while-blocks?
Karl Rupp
rupp at mcs.anl.gov
Mon Jan 21 15:28:24 CST 2013
as some of you already noticed, there's progress on the PETSc style
front. I'm now mostly done with adding simple checks not requiring a
full-fledged compiler for it. Instead, they are simple find/grep/python
calls and fairly accurate. A daily HTML report is currently available
here (click on numbers for details):
http://krupp.iue.tuwien.ac.at/petsc-style/
One thing is fairly fuzzy, though. The style guide requests
if (...) single_line_here
instead of
if (...)
single_line_here
So, in the source tree we find various one-liner versions:
if (...) first_statement;
if (...) { first_statement; }
if (...) {first_statement;}
if (...) { one_statement; second_statement; }
if (...) {one_statement; second_statement;}
if (...) {one_statement;second_statement;}
with the latter often being used with CHKERRQ. On the other hand, the
style guide says
'The closing bracket } should always be on its own line.'
which contradicts all uses except
@all, particularly Barry:
What should be the unified guideline(s) in such cases (if/for/while)?
Best regards,
Karli
