[petsc-dev] Coding style and its violations...
    Peter Brune
    prbrune at gmail.com
    Thu Jan 17 16:10:33 CST 2013
That's awesome!  One brief note is that the fortran stubs generator doesn't
acquiesce to social shaming and as such its output should probably be
ignored. :)
- Peter
On Thu, Jan 17, 2013 at 4:05 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hello again,
> I've set up a couple of scripts checking for compliance with the coding
> styles and started with the removal of tabs. There's also a little page set
> up for tracking the current progress (i.e. the work left to be done):
>   http://krupp.iue.tuwien.ac.at/**petsc-style/<http://krupp.iue.tuwien.ac.at/petsc-style/>
> The page is automatically generated from a bash script calling the various
> checker scripts and may be run nightly via a cron job. Further details on
> the violations can be found when clicking on the number of violations
> found. My goal is to reach 'all green' within the next couple of days and
> then to integrate the 'most failsafe' scripts into Mercurial.
> I'm also thinking about a similar simple overview page for the nightly
> tests, but that's a different story...
> Best regards,
> Karli
> On 01/15/2013 02:47 PM, Barry Smith wrote:
>> On Jan 15, 2013, at 2:42 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
>>  Dear all,
>>> quoting a recent commit:
>>>  BarryFSmith committed 16 hours ago (raw commit)
>>>> silly code formatting problems; some people still need to read the
>>>> style guide
>>> So we have a style guide that is partially respected, partially ignored.
>>> Some things are pretty hard to check automatically, while others are rather
>>> simple. So let's pick
>>>   "No tabs are allowed in any of the source code."
>>> as an example and run
>>> $petsc-dev/src> find . -name *.h -type f | xargs grep -P '\t' | wc -l
>>> to pick the number of violations in .h-files. I get 3215 hits, which is
>>> still small compared to the 8797 hits in .c-files.
>>     It takes little more time to fix the problem then detect it :-)
>>> So, what can we do to reduce the number of violations of the style guide
>>> and keep the number of violations as small as possible in the future?
>>> - First and foremost, eliminate (as many of the) existing violations (as
>>> possible) and come to a clean state.
>>     Yes
>>> - Run pre-push-scripts on bitbucket on the diff. They may not find all
>>> violations, but at least check for the most obvious ones.
>>     Yes. Jed is too in love with Git to ever do this so you have to.
>>> - Add nightly tests on the source tree. We can compare the output of a
>>> properly configured uncrustify against the existing source files and
>>> complain on a mismatch.
>>       The problem is that uncrustify is exactly the PETSc style so we
>> can't do that comparison automatically. Otherwise we would just run
>> uncrustify on all pushes.
>>> Unless there are objections, I'm willing to devote some time on that
>>> while playing with options for a better testing environment. I don't think
>>> that a full elimination of all violations is ever possible nor reasonably
>>> attainable. However, a reduction of violations simplifies the handling of
>>> the code base considerably and is thus worth the effort.
>>     Yes
>>> Best regards,
>>> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130117/56d5ac0c/attachment.html>
