[petsc-dev] example broken for a while src/mat/examples/tests/ex104.c
Tue Jan 15 17:11:49 CST 2013
On Tue, Jan 15, 2013 at 5:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jan 15, 2013, at 5:03 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > On Tue, Jan 15, 2013 at 4:43 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > It works for me.
> >    Cause you are running an install with Elemental, without elemental
> install it goes bad.
> > Isn't that why the elemental tests are in TESTEXAMPLES_ELEMENTAL? The
> other runs fine for me without elemental, e.g.,
>   Don't for me:
Rounding problem? How different are they?
> Barrys-MacBook-Pro:tests barrysmith$ make runex104
> 0a1,25
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Object is in wrong state!
> > [0]PETSC ERROR: C != D!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Development HG revision:
> 34c1b366b0f8fabca0e1f952a026363f6ea75443  HG Date: Fri Jan 11 14:02:35 2013
> -0600
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ./ex104 on a arch-gnu named Barrys-MacBook-Pro.local by
> barrysmith Tue Jan 15 17:09:12 2013
> > [0]PETSC ERROR: Libraries linked from
> /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> > [0]PETSC ERROR: Configure run at Fri Jan 11 21:09:18 2013
> > [0]PETSC ERROR: Configure options --download-blacs --download-cmake
> --download-fftw --download-fiat --download-generator --download-hypre
> --download-libyaml --download-metis --download-ml --download-mpich
> --download-mumps --download-parmetis --download-ptscotch
> --download-scalapack --download-scientificpython --download-superlu
> --download-superlu_dist --download-triangle --download-yaml
> --with-afterimage --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java
> --with-openmp --with-pthreadclasses --with-server --with-shared-libraries
> PETSC_ARCH=arch-gnu --download-sowing
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: main() line 74 in src/mat/examples/tests/ex104.c
> > application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
> > [cli_0]: aborting job:
> > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > =   EXIT CODE: 73
> > =   CLEANING UP REMAINING PROCESSES
> > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> /Users/barrysmith/Src/petsc-dev/src/mat/examples/tests
> Possible problem with ex104, diffs above
> > $ make PETSC_ARCH=mpich-clang ex104 runex104
> > /home/jed/usr/mpich-clang/bin/mpicc -o ex104.o -c -fPIC -Wall
> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline
> -O0   -I/home/jed/petsc/include -I/home/jed/petsc/mpich-clang/include
> -I/usr/include -I/usr/cbind/include -I/usr/forbind/include
> -I/home/jed/usr/mpich-clang/include    -D__INSDIR__=src/mat/examples/tests/
> ex104.c
> > /home/jed/usr/mpich-clang/bin/mpicc -fPIC -Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0  -o ex104
> ex104.o -Wl,-rpath,/home/jed/petsc/mpich-clang/lib
> -L/home/jed/petsc/mpich-clang/lib  -lpetsc
> -Wl,-rpath,/home/jed/petsc/mpich-clang/lib -lsundials_cvode
> -lsundials_nvecserial -lsundials_nvecparallel -llapack -lblas -ltriangle
> -lX11 -lpthread -lchaco -Wl,-rpath,/usr/lib -L/usr/lib -lexoIIv2for
> -lexoIIv2c -lnetcdf -lm -Wl,-rpath,/home/jed/usr/mpich-clang/lib
> -L/home/jed/usr/mpich-clang/lib
> -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.2
> -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.2 -lmpichcxx -lstdc++ -ldl
> -lpmpich -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -ldl
> > /bin/rm -f ex104.o
> >   /* Test MatTransposeMatMult() */
> >   ierr =
> PetscObjectTypeCompare((PetscObject)A,MATELEMENTAL,&iselemental);CHKERRQ(ierr);
> >   if (!iselemental){
> >     ierr =
> MatTransposeMatMult(A,A,MAT_INITIAL_MATRIX,fill,&D);CHKERRQ(ierr); /* D =
> A^T*A */
> >     ierr = MatEqual(C,D,&equal);CHKERRQ(ierr);
> >     if (!equal) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_WRONGSTATE,"C !=
> D");
> >     ierr = MatDestroy(&D);CHKERRQ(ierr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130115/66168136/attachment.html>
