[petsc-dev] Compliant C89
    Satish Balay
    balay at mcs.anl.gov
    Mon Jan 14 16:34:02 CST 2013
On Mon, 14 Jan 2013, Jed Brown wrote:
> Regardless, Satish, can you set up a build --with-64-bit-indices
> CFLAGS='-std=c89 -pedantic -Wno-long-long'?
Added 2 different builds for these options.
https://bitbucket.org/petsc/petsc-dev/commits/ea7d7e14f0425f98ed345b1490243b7c
I've enabled --with-64-bit-indices with metis/parmetis/pastix etc that
are supporsed to work with it - but the builds are failing.
Satish
