[petsc-dev] Compliant C89
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Jan 14 11:33:29 CST 2013
On Mon, Jan 14, 2013 at 11:17 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Note that even if you change it to an inline function it still will not
> give the correct stack frame since it is not inside the
> PetscFunctionBegin/End.
The point is that an inline function routine couldn't be called in a
declaration, so it would force people to move it. You're right that it
looks like it was only used incorrectly in the places fixed here.
https://bitbucket.org/petsc/petsc-dev/commits/59c614dd5ce57f9497e794f6495fc91990a89274
>   Shouldn't we simply ban its use in the declarations part of the
> routines?
I thought it was already banned and that nobody was paying attention, sort
of like the // comments.
> Note that its use in, for example,
>     } else {
>       PetscBLASInt ione = 1;
>       PetscScalar aone = 1.0, azero = 0.0;
>       PetscBLASInt neqs = PetscBLASIntCast(bcgsl->ell-1);
> is legal since it is within a PetscBegin/Return block and the last
> declaration given.
> A quick etags search found that it is being used correctly already almost
> anywhere. The suspicious place is only in the documentation :-)
> Thus I say, fix the documentation and check that it is never used
> incorrectly but don't change its form.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130114/52302691/attachment.html>
