[petsc-dev] Compliant C89
Jed Brown
jedbrown at mcs.anl.gov
Mon Jan 14 09:02:42 CST 2013
The cast macros like PetscBLASIntCast() are not "safe" in that they include
two separate statements. Unfortunately, we cannot do better with C89 unless
we pass the target as an argument. Regardless, these casts *cannot* be used
in declarations.
PetscBLASInt one = 1,bn = PetscBLASIntCast(xin->map->n);
PetscErrorCode ierr;
This is invalid C89 because once the macro expands, there is a statement
before the next declaration. Furthermore, the check calls SETERRQ in case
of failure, so it *must* be inside a PetscFunctionBegin/PetscFunctionReturn
block.
Should we change this cast to an inline function (or equivalent macro) so
that this usage is more explicit?
Regardless, Satish, can you set up a build --with-64-bit-indices
CFLAGS='-std=c89 -pedantic -Wno-long-long'?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130114/837822e4/attachment.html>
