[petsc-dev] Clique support
Jack Poulson jack.poulson at gmail.com
Fri Jan 11 13:58:34 CST 2013
Yes, this is essentially my fault. I temporarily dropped off of the map due
to needing to eventually defend a dissertation and graduate. There are a
few issues related to the build system for Elemental and Clique that I hope
to resolve soon (namely, making it easy for Clique to use an external
Elemental installation) which should make the integration easier.
Jack
On Fri, Jan 11, 2013 at 11:43 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> No, it hasn't been finished. You can watch this issue or contribute code.
> https://bitbucket.org/petsc/petsc-dev/issue/28/clique-interface
> On Fri, Jan 11, 2013 at 1:32 PM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
>> Hello PETSc devs,
>> I am aware that the support for Jack's solver was on the way, but somehow
>> no news came since a long time. Is this possible to test it at the moment?
>> Thanks.
>> Regards,
>> Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130111/6edfd413/attachment.html>
