[petsc-dev] Counting Fortran function pointers
Richard Tran Mills rtm at eecs.utk.edu
Thu Jan 10 00:37:17 CST 2013
Thanks, Jed.  I did think the static numbering looked pretty kludgy when
I started messing with the DMShell Fortran stubs.  I'll switch to the
new system.
--Richard
On 1/9/13 8:37 PM, Jed Brown wrote:
> Richard, I pushed a new Fortran callback handling system. It is
> subtype-safe and doesn't rely on crazy static numbering. You can see
> what is left to do by
> $ grep AllocateFortran src/**/*.c
> Once these are gone, we can delete the old system.
> Meanwhile, you can add new functions using the system here. The Set
> call will create a callback ID if it doesn't exist yet and the object
> will automatically handle resizing and resetting when you change subtypes.
> https://bitbucket.org/petsc/petsc-dev/commits/f2a68b8a037edffd463d1ee6e9014e2edcd4aad7
> a couple more instances:
> https://bitbucket.org/petsc/petsc-dev/commits/bc94ac15bf5a75c3290770efe7e624a46ddcad37
> On Mon, Jan 7, 2013 at 5:48 PM, Jed Brown <jedbrown at mcs.anl.gov
> <mailto:jedbrown at mcs.anl.gov>> wrote:
>     Richard, it's better to mail the list. No, we haven't reworked
>     subtype Fortran pointers yet, but I think we know what needs to be
>     done.
>     On Mon, Jan 7, 2013 at 1:42 PM, Richard Tran Mills
>     <rtm at eecs.utk.edu <mailto:rtm at eecs.utk.edu>> wrote:
>         Hi Jed,
>         I am back at work after some extended time away and I need to
>         start messing with DMShell so that I can use it to set
>         operations like LocalToGlobal and GlobalToLocal updates from
>         inside PFLOTRAN.
>         Did this issue of handling the Fortran function pointers get
>         resolved somehow?  Is there something I need to change in how
>         I am doing the Fortran bindings?
>         Cheers,
>         Richard
>         On 12/4/12 5:43 PM, Jed Brown wrote:
>>         As usual, anything that is duplicated and not checked by the
>>         compiler is broken.
>>         $ grep PetscObjectAllocateFortranPointers src/**/*.c
>>         src/dm/impls/da/ftn-custom/zda2f.c:
>>          PetscObjectAllocateFortranPointers(*da,6);
>>         src/dm/impls/shell/ftn-custom/zdmshellf.c:
>>          PetscObjectAllocateFortranPointers(*dm,2);
>>         Note that changing the type does not reset the function
>>         pointers, thus having a DMSHELL, calling DMSetType(dm,DMDA),
>>         and then setting a DMDA local function will cause memory
>>         corruption.
>>         I cannot express how much I hate this system. The full-blown
>>         solution is that for each type, we register a (global) token
>>         which is the index of that function pointer. That doesn't
>>         have any false dependencies, but is more "initialize" code.
>>         An alternative, used in the TS and KSP code below, is to have
>>         a common enum that lists all the Fortran functions. It's a
>>         false header dependency, but not a binary dependency.
>>         What should we do? The current state is a disaster.
>>         src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.c:
>>          PetscObjectAllocateFortranPointers(*ksp,3);
>>         src/ksp/ksp/interface/ftn-custom/zitfuncf.c:
>>          PetscObjectAllocateFortranPointers(*ksp,FTN_MAX);
>>         src/ksp/pc/impls/mg/ftn-custom/zmgfuncf.c:
>>          PetscObjectAllocateFortranPointers(*mat,1);
>>         src/ksp/pc/impls/shell/ftn-custom/zshellpcf.c:
>>          PetscObjectAllocateFortranPointers(*pc,5);
>>         src/mat/impls/mffd/ftn-custom/zmffdf.c:
>>          PetscObjectAllocateFortranPointers(*mat,2);
>>         src/mat/impls/shell/ftn-custom/zshellf.c:
>>          PetscObjectAllocateFortranPointers(*mat,11);
>>         src/mat/interface/ftn-custom/zmatrixf.c:
>>          PetscObjectAllocateFortranPointers(*sp,1);
>>         src/snes/interface/ftn-custom/zsnesf.c:
>>          PetscObjectAllocateFortranPointers(*snes,14);
>>         src/snes/linesearch/impls/shell/ftn-custom/zlinesearchshellf.c:
>>          PetscObjectAllocateFortranPointers(*linesearch,3);
>>         src/snes/linesearch/interface/ftn-custom/zlinesearchf.c:
>>         src/sys/draw/utils/ftn-custom/zzoomf.c:
>>          PetscObjectAllocateFortranPointers(*draw,1);
>>         src/ts/interface/ftn-custom/ztsf.c:
>>          PetscObjectAllocateFortranPointers(*ts,OUR_COUNT);
>         Richard Tran Mills, Ph.D.
>         Computational Earth Scientist      | Joint Assistant Professor
>         Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
>         Oak Ridge National Laboratory      | University of Tennessee, Knoxville
>         E-mail:rmills at ornl.gov  <mailto:rmills at ornl.gov>   V:865-241-3198  <tel:865-241-3198>  http://climate.ornl.gov/~rmills  <http://climate.ornl.gov/%7Ermills>
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130110/33807884/attachment.html>
