[petsc-dev] [mpich-discuss] MPICH migration to git
Dmitry Karpeev karpeev at mcs.anl.gov
Wed Jan 9 22:25:25 CST 2013
On Jan 9, 2013 10:13 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
> On Jan 9, 2013, at 10:03 PM, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> > On Jan 9, 2013 9:51 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
> > >  Then I would consider switching over to git and proceeding to make
fun of hg users,
> > Is this the only reason to switch?
>     Yes, making fun of other people is the highest priority.
> > Since otherwise it would have to be equivalent to hg (as per your
aforementioned requirements). Besides, currently there is no
globally-visible use of branches in the petsc workflow, as far as I can
tell. Finally, you would have to deal with the INDEX and the extra states
that it implies.
>    Sorry I was not clear. ___I____  want to be able to continue with my
simple-minded work flow and have it be compatible with what other people
do. It is fine if Jed and Karl and Matt and whoever uses all kinds of cool
Git features so long as it doesn't make ___my___ workflow too
intellectually difficult for me. That is I only object to the change if it
requires always wrestling with several new concepts that don't exist in Hg.
 I do
>   hg clone
>   hg pull
>   hg commit
>   hg merge
>   hg push
> I want to be able to do something similar with git; I don't want new
__required__ things introduced like
>   git sanitize  x y z
> where x y z are particular changing options that I HAVE to magically know
what they are each time and get right or I fuck myself over.   Which did
happen the one time I tried to use one of Jed's git repositories when it
won't let me push because I hadn't indicated the right branch or some such
shit. That is I don't want the repository system to require __me__ to keep
in my brain any state information that I need to convey to the repository
when interacting with it each time.
I think the presence of the index will be the biggest curveball for you.
>    Barry
>    Barry
> > Dmitry
> > >    Barry
> > > > On Wed, Jan 9, 2013 at 5:48 PM, Barry Smith <bsmith at mcs.anl.gov>
wrote:
> > > >   Yes but given their absolutely horrible decision to stick with
SVN all these years I cannot trust their decision to go with GIT. Sadly
this is a very big argument for NOT switching PETSc to GIT. This email is
only partly in jest, it has a serious component as well: is the "everyone's
switching to git" just a case of the sheeple following the latest new thing
without a proper technical evaluation or is it a carefully thought out
decision?
> > > >    Barry
> > > > On Jan 8, 2013, at 6:38 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > > > > Everyone's doing it. ;-)
> > > > > ---------- Forwarded message ----------
> > > > > From: Dave Goodell <goodell at mcs.anl.gov>
> > > > > Date: Tue, Jan 8, 2013 at 6:23 PM
> > > > > Subject: [mpich-discuss] MPICH migration to git
> > > > > To: discuss at mpich.org
> > > > > MPICH users & developers,
> > > > > The MPICH project has transitioned from using SVN as our version
control system (VCS) to using git instead.  Details of the switch are
described here:
> > > > > http://wiki.mpich.org/mpich/index.php/Git
> > > > > Highlights from the document and the transition:
> > > > > * Read-only git clones are available at
http://git.mpich.org/mpich.git and git://git.mpich.org/mpich.git
> > > > > * All critical history from SVN has been imported into the git
history.
> > > > > * The SVN server and its associated history are not going away,
although it has been made read-only.
> > > > > We continue to work through our documentation and automated
processes (cron jobs, etc.) to update them to the new system.  Our trac
instance will transition to understand the new VCS soon, although it
currently displays only historical SVN data.
> > > > > Please bear with us as we work through this transition period.
 If you have trouble with the new setup, please contact devel at mpich.org or
discuss at mpich.org for assistance.
> > > > > Regards,
> > > > > The MPICH Team
> > > > > _______________________________________________
> > > > > discuss mailing list     discuss at mpich.org
> > > > > To manage subscription options or unsubscribe:
> > > > > https://lists.mpich.org/mailman/listinfo/discuss
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130109/fa6b9401/attachment.html>
