[petsc-dev] Documentation comment support
Karl Rupp rupp at mcs.anl.gov
Wed Jan 9 09:37:50 CST 2013
Hi Barry,
the 'shaky scripts' will mostly be required with a 'no touch' policy on
existing sources, i.e. adjusting the comment blocks such that they are
recognized by doxygen. I get your point regarding a doxygen dependency,
yet a dependency for a documentation system is much more controllable
than a runtime library which you need to get installed at the user's
machine.
The Fortran stubs certainly need additional consideration, yet I propose
to have a closer look at what Doxygen can deliver rather than turning it
down upfront.
Best regards,
Karli
On 01/09/2013 12:06 AM, Barry Smith wrote:
>    If we really need to write a hierarchy of shaky scripts to use oxygen, then why not just write a hierarchy of shaky scripts (like we do now) and not use doxygen?
>     Doxygen is an ugly dependency unless it truly delivers some fantastic feature we cannot reproduce I think it should be avoided. So what is that fantastic feature?
>     Barry
>    Yes sowing is an ugly dependency but at least it is OUR dependency. And yes I have no problem with Matt rewriting all of sowing in python :-)
> On Jan 8, 2013, at 9:32 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Tue, Jan 8, 2013 at 8:45 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
>> I was thinking of using an input filter, perhaps after creating an index.
>> http://www.stack.nl/~dimitri/doxygen/manual/config.html#cfg_input_filter
>> If a single filter is sufficient for all files, this is indeed the better option. Thanks.
>> We get the file name in argv[1] so it can use the path to do different things. For example, examples/tests/ are treated differently from examples/tutorials/, which are different from library code.
