[petsc-dev] Documentation comment support
Barry Smith
bsmith at mcs.anl.gov
Wed Jan 9 00:06:54 CST 2013
If we really need to write a hierarchy of shaky scripts to use oxygen, then why not just write a hierarchy of shaky scripts (like we do now) and not use doxygen?
Doxygen is an ugly dependency unless it truly delivers some fantastic feature we cannot reproduce I think it should be avoided. So what is that fantastic feature?
Barry
Yes sowing is an ugly dependency but at least it is OUR dependency. And yes I have no problem with Matt rewriting all of sowing in python :-)
On Jan 8, 2013, at 9:32 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Jan 8, 2013 at 8:45 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> I was thinking of using an input filter, perhaps after creating an index.
> http://www.stack.nl/~dimitri/doxygen/manual/config.html#cfg_input_filter
> If a single filter is sufficient for all files, this is indeed the better option. Thanks.
> We get the file name in argv[1] so it can use the path to do different things. For example, examples/tests/ are treated differently from examples/tutorials/, which are different from library code.
