[petsc-dev] Documentation comment support
Jed Brown
jedbrown at mcs.anl.gov
Tue Jan 8 21:50:43 CST 2013
On Tue, Jan 8, 2013 at 9:43 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Those wimps just call cpp instead of writing the preprocessor in Python
> too (I did this). That means
> you cannot regenerate properly.
Well, sort of. You have the original source around and you have the AST for
what goes where. Preprocessing throws code transformation for a loop
however you shake it. LLVM is a much heavier dependency and the Python
interface is not as nice. Pick your poison.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130108/931b0954/attachment.html>
